Originally Posted by redmt
It's a 351 BASED motor at 418 inches. Expected HP should be in the 575 + range. The injectors were recommended by another guy who as it turns out doesn't know as much as he thinks he knows. The shop that is going to set it all up has recommended that #39 injectors will be more than enough.
The problem I'm having is finding the correct injector to fit the manifold as the FR injectors are too tall.
redmt. you can order the injectors that I put in my post by going to the Inglese web site. Part#30397-8 are the #39 injector. I believe they are what GM uses in there cars.
