I get an engine flutter when taking a hard turn. My levels were in the middle of the plastic float windows. I think I need to lower them. The plastic float windows are intended for temporary use only. I had the plastic windows in my carb when I purchased it used and when fooling with the floats found they had dissolved to the point where they were about ready to leak and quite dangerous. Only use the clear plastic inserts for adjustment. Once the floats are set where you want them, put in the brass inserts for normal use.
