Have you measured how far from level the carb is sitting? A degree or two of slope will probably not affect the float bowls and adjustment much. Three or more degrees could create some float bowl issues.
It's always good to use a thermo spacer under the carb, if you have room for it. The carb wedges can be as much as 3/4 inch thick at the thickest end. If you end up going that route you may not have room left for a thermo spacer.
