Old 01-09-2013, 12:33 PM
Bernica's Avatar
Bernica Bernica is offline
Senior CC Premier Member
Originally Posted by YerDugliness View Post
I remember when you were developing the base plate, great work!
I might add that it probably will NOT work with an Edelbrock/Carter type carb. There is a portion of the choke assembly linkage on the passenger's side that would interfere with the flat base plate. I managed to machine down the Mr. Gasket base that I run on my setup for a bit more hood clearance, but would REALLY like to run the nicely radiused K&N base....the Mr. Gasket base has a sharp corner, the K&N base is almost like a funnel.
Good to know MickMate has them....great adaptation and fits inside the Turkey pan, to boot!
Cheers!
Dugly
Thanks Dugly,
I will start studying the Carter AFB / E-Brock Carb next. I enjoy it when folks say things can't be done.
Cheers back!
