Old 01-11-2013, 02:44 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Im running a csr electric pump on the big block..... I set it up with a turbo timer...you can set how long you want it to run for after you turn the engine off Ive got the thermo fan connected as well it runs for 30 seconds after you turn off the engine this stops the water boiling in the heads and stops water being pushed into the bottle
