  #50 (permalink)
Old 01-12-2013, 01:45 PM
Rebel1 Rebel1 is offline
Originally Posted by AC-460 View Post
Just checked my front end ....pretty sure my caster is running at 0....if I change to seriies one arms will this help and roughly what degrees will it give me
Short answer is yes but will it give you all the caster you want?.
That is assuming you want something between say 4 and 6 degrees.
Were you able to identify which upper and lower arms you currently have?.
The series 1 uppers will allow about 1/4" extra caster over the series 11 arms. Then say putting the three caster shims to the front of the ball joint will give you an extra 1/8" making a total of 3/8".
If you currently have a series 1 lower arm then changing to a series 2 lower will allow you an extra 1/4" of caster.
