Old 01-14-2013, 04:45 AM
Modena's Avatar
Modena Modena is offline
Default How much rear-suspension droop below ride-height?
I am assembling the rear suspension and have taken some quick measurements. With the rear hub jacked to ride height, and the shock connected (without spring), I measured over 75mm of bump from ride height in the setup, and 35mm of droop from ride height before the shock is at full extension.
How much droop do other people have below ride height? There's not much info out there on the Interweb that I can find, I think this information is going to be quite specific to suspension setup, shock valving etc, but comparing with other Cobra's is the best place to look me thinks!
Ben
Ben in AU
