Old 01-15-2013, 08:19 AM
blykins blykins is offline
1. I'd check the lash fairly frequently. That's a pretty stout cam as far as lobe aggression goes. I couldn't find that intake lobe in the catalog, but the exhaust lobe is an RT series, which is pretty aggressive. I don't know how often you drive, but I'd probably check the lash once a month.
2. Hopefully some of the members local to you will chip in here.
3. 8 Stack carb or 8 Stack EFI? Each would require a different camshaft to be a solid performer. Unless you go with a self tuning EFI system, you won't find anything easier to tune than that Dominator.
4. Yes, unless you go with a self tuning EFI.
5. That engine with that cam and that car is going to be an on/off switch as far as power, so just be careful.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
