01-15-2013, 09:24 AM
KY
If initial is set at 18 with the black bushing, you should be at 36 degrees total, so that will be pretty close....you would probably need to get it on a dyno to see the difference in +/- degrees.
Two light blue springs should put total timing in by 2500. In a lightweight Cobra, that's perfectly fine. Barry's spring setup would be quicker on the curve. You may notice a difference and you may not.
