Buzz, before you go any further, I would suggest that you pull the plug on that cylinder and swap it with one from the other side of the engine. See if that moves the problem. If it doesn't then swap the plug wires and see if that moves the problem. Could be a bad connection inside the wire or a cracked insulater on the plug.
