Originally Posted by 750hp
Beautifully fabricated, as always Mike. I haven't seen how far people push the envelope with dead headed systems. Are you confident that there won't be a pressure drop in the fuel rails at WOT?
Thanks Craig.
My theory is that the rails are 3/4" ID which is quite a bit larger than stock. The main line feeding them is 1/2" where the stock line is 5/16" I think. So there is a heap more flow and volume in both of those which should keep a good head of fuel available. Then the Pump is an 044 which will be able to keep up with any demands I can throw at it.
Hopefully the regulator will respond fast enough to keep up with any pressure drop.
Fingers crossed it all works.
