Old 01-21-2013, 06:27 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
First of all, you may or may not have the hole drilled in the crossmember for adding shoulder harnesses - That depends on your chassis number. I have a write-up whith photos on how to install the shoulder harnesses. Send me your email address offline and I'll send you a copy. You will most likely need to remove your rear wheels to access the bolts unles you have a lift and have long (LONG) arms.
SPFWiringDiagrams@Comcast.net
