I would bet you're experiencing more of a lack of traction than power. These are not all Wheel drive . You Have at best 1 And 1/2 tires to put the power to the pavement.
Your BDR with an aluminum block should be at around 2300 pounds. at your rated power even if your Motors torque Curve may be high probably maxing over 5500 RPMs Throwing any more power added May only make the situation worse.
