Old 03-10-2002, 03:43 PM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
Cobra Dude,
I believe you are out of luck on the T-10 fitting that bellhousing. However, Lakewood brought out not long ago a bellhousing for the Richmond T-10 to a Ford small block. Remember though, the Richmond uses a Chevy input shaft. I am using this setup, with a Center Force billet flywheel and a Duel Force clutch with Chevy spline disc. This is the setup Center Force recommended. I will be leaving tomorrow for a week but if you are interested in the numbers I will get them for you upon my return.
Bill Kozlow
