Old 01-30-2013, 07:54 PM
DanEC's Avatar
DanEC DanEC is offline
Default Steering column play
After installing my steering column (ERA) I've noticed it has a little more lateral play at the hub than I expected. I seated the hub as tight on the shaft as it would go before tightening the upper and lower clamps but it still has a little up/down and side to side movement. Is there anything I'm missing on installing the column or is a little play normal?
Thanks
