Old 01-31-2013, 06:09 AM
DanEC's Avatar
DanEC DanEC is offline
I have both clamps tight. To be a little clearer - the play is between the shaft/hub assembly and the column and collar - not the entire column assembly to dash. I've rebuilt the steering column on my old Vette before and I'm familiar with how the shaft/hub have to be adjusted tight without any longitudinal play to fully seat the bearing and avoid play. Just not sure if there may be something I haven't got set up quite right on this one. I do need to check the big bolt securing the hub. I assume it was tight from the factory but maybe not.
Dan
