Thanks Sammy (and others). FWIW, I was looking through the engine documentation and it seems initial timing was set at 35 degrees (many samples were run some as low as 32). Also the Flywheel is a MCL billit alluminum flywheel.
Rick - thanks - I have sent you a PM
I am going to measure / review as much as possible this weekend b/c I did not install the motor. Once the building had it ready, I had another party install the motor, bellhousing and twm stack injection. He and I have talked this as well b/c he put the second flywheel starter in and talked with Robb at RobbMC to make sure specs were right. Thus I don't have much more information to go on this point.
