Old 02-01-2013, 09:24 AM
rpatton3's Avatar
rpatton3 rpatton3 is offline
Cobra Make, Engine: Backdraft 874 solid red Roush 427 small block 515 hp
Default e15
Originally Posted by bliss View Post
AAA warns E15 gasoline could cause car damage
"E15, a higher blend of ethanol and gasoline, has rolled out in a handful of states. But its use in older vehicles is generating warnings from AAA, which says E15 could be harmful to pre-2012 vehicles."
Has anyone run into this as an issue yet? Of course, Cobra's have engines that are not 2012 versions in a lot of cases - most cases, so if E15 is the only option - just fill it up?
Get pure-gas app for your phone, make friends with cropduster for 100 av gas, don't buy E15 and be happy you can get something to help alleviate the E15's affinity for water if you have to get E15. Drive your car so fuel won't go bad.
http://www.brighterenergy.org/25932/...k-on-e15-fuel/
Ethanol spurring new cases of sad cow « Hot Air
e15 | Search Results | CowboyByte
There were no atheists in the foxholes.
