Originally Posted by Jerry Clayton
KISS
keep it simple s--------------------------------
Remember that for every corner that the accusump keeps your oil pressure up, It also takes away while it refills down that straight after the corner while you are running it to 7000 between the gears----
Oh, bet nobody ever noticed their oil pressure while turning 7000 -----------
Definitely apply KISS, and on everything you do with these machines. I've always been an advocate of using the highest volume
oil pan you can fit, when shock compression puts you in contact with asphalt backoff a little
