  #25 (permalink)
Old 02-01-2013, 02:26 PM
AL427SBF AL427SBF is offline
Originally Posted by lippy View Post
But that would only work with an electric oil pump
You guys are on your toes, just checkin'
How Accusump works, again from their website -
The Accusump is connected to the pressure side of an engine's oiling system and is charged by the engines own oil pump. Its simple, efficient design revolves around a hydraulic piston separating an air pre-charge side and an oil reservoir side. On the oil side of the Accusump it has an outlet that goes into the engine's oiling system, controlled by a valve. On the air side it's equipped with a pressure gauge(on oil accumulators only) and a schrader air valve, which allows you to add a pre-charge of air pressure to the Accusump.
