Old 02-01-2013, 05:15 PM
razerwire razerwire is offline
Cobra Make, Engine: csx4163 full comp alu. body
Used black and white tile, porcelain 12", used half as much of the best thin set. Drive bus conversion on tile and have 4 post lift setting on 1/4" rubber belting. Down about 4 years now. Had race deck and pulled up, had same dislikes as others with the added problems of buckling when I would stop bus or turn bus. Doors face south and race deck would buckle from sun. I did leave 3/4" around edges like instructions said. Put the best epoxy down on other garage I just finished. Was 2 part not mix with water cheap stuff, I do not really like to much. Scratches too easy and seams to stain easy. Had to go with 2 coats to cover good. Only problem I have with tile is that it is slippery when wet. I like to put a few drops of simple green in mop bucket and mop out once in while but you have to be careful until it drys. Just use dust mop to keep clean. Also have 3 tiles cracked where I left the door up and the sun beat on 4 days in 96 degree weather. Easy to pop out and replace when it gets to bothering me. Tile was .75 cents each.
