Old 03-11-2002, 06:37 AM
JAM1775 JAM1775 is offline
Cobra Make, Engine: SPF 974
I have the Pro Flow and run it no longer with the stock foam element but with a much better flowing foam element. I have not had either one show signs of deteriorating or melting in 2 years 4000 miles. I recently purchased the de-humidifier filter element at Home Depot and will install before the summer season. You do not want to backfire thru the carb with the Pro Flo for obvious reasons. But melting under normal driving is extraordinary .
I mounted my Pro Flo on a Moroso Air Pan from Jegs then
trimmed the foam on the pan to seal around the hood scoop.
