Thread: Subaru Guys
Old 02-05-2013, 03:54 PM
ERA2076 ERA2076 is offline
Cobra Make, Engine: ERA - B2Motorsports Dart 331
Originally Posted by strictlypersonl View Post
It would take a pretty weirdly shaped intermediate to substitute for the rubber bushings. You might be able to shim the current setup to take any play out. If you actually have the Subaru gear (as opposed to the modified equivalent Mustang II that we supplied for a while), we've got some replacement urethane bushings, but they are only slightly harder than the Subaru's rubber.
The major alternative is to change to the later rack which uses Mustang bushing-type mounts. That would require torching your old mounts off and replacing with new brackets, plus a new lower steering column.
Yes - it will take some very strange shapes - lol!
I assume Subaru because that is what the previous owner thought he had. I have considered the newer rack, but when we replaced the boots on this one it appeared to be in good order though slipping in the mounts. The Mustang mounting IMO is a much better arrangement and something I am familiar with, but I am going to try to make this work first. We plan on machining some widgets to replace the rubber and solidly locate it. I was just wondering how any others had approached it.
x-chr
