Mike,
I did the same, as Ben said, from memory its 15mm down to 14mm.
I took the pinion out (easy job), set it up in the mill and chattered badly, the shaft is obviously hardened.
I ended having to surface grind it, with a stone in the mill.
Dave
http://cobra-cr3514.blogspot.com/
