Old 02-11-2013, 07:50 AM
DanEC's Avatar
DanEC DanEC is offline
I should have noted that there are more leads connecting to the alternator also than the 2 leads/Alt and 2 leads/regulator on an old Chrysler system I recently trouble tested. Jumping leads between alternator and battery should tell me the system is charging if Voltage is around 14 - 14.5. If down around 12.5 volts I need to know which leads need to be checked to check the regulator field.
