Coyote 5.0L on Dyno
FYI. If you go with Coyote 5.0L make sure you go on Dyno soon after the motor is installed. New build 10/12/12, only road tested, and ran into a fuel problem, sensor was bad on right side. The only way to identify the problem, was on the Dyno...That is the only way to deal with any issues with the engine..Also make sure you purchase a SCT 3015 vehical programmer..Hope this is helpful to those who want to go Coyote. Once on the Dyno should keep your hood down alot longer than the carb. set up.
