02-16-2013, 03:00 PM
AR
OK - I'll try in the morning. Both front parking lights come on with the switch on and the key off. The front lights appear of equal brightness. The red wire is lighting the parking light filiment. I'll try jumping it to the green parking light lead (turn signal I presume) and see what happens.
I can't see what difference it makes but this is the light that did not have a housing ground in the harness. I made a ground and jumpered it over to the other parking light to ground it.
And I'll crawl back under the dash to check the harness connections that the green wire runs through.
thanks Bob
