Patrick
I jumped the positive cable connection at the starter relay to the gound on the voltage regulator and got 12.8 volts (I've had the charger on the battery).
I then unplugged the regulator, installed a jumper lead on the yellow wire and connected to the positive meter probe and turned the key on. I again got 12.7 volts.
I didn't try turning the flashers on since I had voltage.
Thoughts??
