Old 03-11-2002, 06:24 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
In my book, C7ME-A was only used for two different blocks, a 428 block, and a 330 ci MD truck engine. Take off the head and measure the bore. If it is 4.13", then it's a 428, and a good buy. If the bore is 3.875", then it's a 330 block, and is basically worthless unless you want to build a 330 - 350 ci FE. Although the 330 may come with a steel crank, at a 3.5" stroke though.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
