Did all 5 set do the same thing or the set you liked the best?
I have seen one defective bulb back feed the rest. When the customer applied the brakes all his parking lights came on. He had installed LED tail/brake lights. replaced them everything worked correct. try only the rear or front first to eliminate the problem area or bad bulbs...
