Yes, now I understand. If you're throttle bodies are sitting right down on the manifold, I can see where that's a problem. If you have a side mounted throtle cable linkage, you could also have some intereferance with the valve cover.
During initial assembly I had the same problems. My TB's sit on top of aluminum 1.5" spacers.
