02-21-2013, 10:39 PM
GA
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Originally Posted by strictlypersonl
QI bulbs worried me a bit because they are so hot, and these are pretty high wattage (50W/15W), so I tested them in the fixtures. No problem.
These are very bright, so you will never have a "dim bulb" problem again.
Amazon: EiKO 1157 Bulb
Wow! 50 watt... These are double the wattage of the traditional bulb. I'm sure these will not go unnoticed when you hit the brakes or indicate your intention to make a turn.
Thanks!
