02-22-2013, 08:09 AM
GA
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Originally Posted by Hydramada
Thanks for this....
I figured that my problem was that the internal design of the direct replacement LED's for 1157 style bulb is back feeding voltage from the flasher mode into the tail light mode and braking mode into the tail light mode and that Diodes would correct this. I do not have the knowledge on how to select suitable diodes to do this, so the info you've provided is most helpful.
