  #38 (permalink)
Old 02-23-2013, 07:30 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by cscobra View Post
Dan, I have a mechanical VR (Ford reproduction) and initially had the light on/no charge situation you describe. I took the cover off to watch the VR work (hooked up to the car, including ground, but not mounted on the footbox). I noticed one of the two leads to the VR frame from the "bobbins" (for lack of a better term) didn't appear to be soldered as well as the other lead. This was corrected and voila - it now charges. It doesn't seem to get "excited" enough to charge, though, until after the first time the engine has been revved to 1500 rpm or so. Other than that observation, I've had no further charging problems after 200 miles.
Hope this helps - good luck!
I wonder if the same thing may be what I'm dealing with - I just haven't rev'd the engine enough to trigger the VR. Either that or my battery has been too weak. I can't believe that I could have two bad voltage regulators. I pulled the cover on the VR and examined it and found nothing amiss - I think I will give it a try operating it with the cover off to observe it.
I can't bring mysef to start cutting up and modifying the wire harness right now.
Thanks
