Originally Posted by DanEC
Is the manifold opening roughly the correct diameter but apparently another thread pattern - or is it much smaller in diameter than the fitting? I had to drill out and tap my FE Ford aluminum manifold with small opening, for the Smith gage fitting.
The hole in the manifold is larger in diameter than the fitting. It is a loose fit. Did you tap your manifold sae or metric?
