Old 02-26-2013, 03:44 AM
Zedn's Avatar
Zedn Zedn is offline
looks good Mike,
How did you have the header bottle connected before welding it to the pump? I was planning on using one of those inline radiator cap fittings (straight pipe with a neck on it) up close to the water pump and then just using a recovery tank from that rather than having a full header tank.
Did you drill out the steam pipe ports at the rear of the heads also? I cant see a connector in the photo. Not sure how important this is until major mods are made to the engine.
