Old 03-12-2002, 08:59 AM
Roscoe's Avatar
Roscoe Roscoe is offline
I am also using a 351W, lakewood, Centerforce flywheel and clutch, Tremec 3550 and Tilton bearing. The car has been on the road since last June and I have put alot of miles on it and alot of demand on the clutch. I am very pleased with the performance of the whole setup.
As with any hydraulic bearing you have to set it up properly with the correct spacing. Make sure your lines are clear of the clutch and make sure you have a pedal stop as to not overstroke the bearing.
Roscoe
Roscoe
