The PV is usually 1/2 manifold vacuum at idle. It can be really difficult to see if the secondaries are opening by revving the engine with no load. You may have lucked out without destroying the engine. Pull the pan first to see what's going on.
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
