i have a switch, or had a switch. it was a pos longacre with the handle wabble and was only rated for 150 amps, so another is on the way. looking through a nice new electrical book and the guy wired two 200 amp resettable breakers in parallel prior to the switch so i was thinking about something like this, and wondering how many amps the starter does pull. the breakers also had valet mode, so you could disable everything from there also.
i figured allow for at least 250 amps, that is what one of the smaller advertised tilton starters was advertised at. 935 amp surge is a pretty good jolt.
