You have to have adjustability, that is the best part about these cars. Adjustable brakes, adjustable shocks, adjustable sway bars.... don't get any better than that. You can go out on cold tires with the sway bars full soft and heat the tires up then dial the bars in to where you want them to start. Don't forget the adjustable brakes, I could dial in quite a bit more rear brake bias than first imagined and there will be an easily noticeable difference when you get there.
