Old 03-18-2013, 02:21 PM
Danr55's Avatar
Danr55 Danr55 is offline
I just changed my FE from a flat tappet to hyd. roller and I chose a Howards Cam with the Morel lifters. I've been running Comp Cams but the available profiles for FE motors seemed limited unless you went with a custom grind. I found exactly the grind I wanted with Howards. As for roller rockers and springs, I got the entire assembly from Precision Pumps in California. So far, they've worked well.
Dan in Arizona
CCX3209
