![Old](/forums/images/statusicon/post_old.gif)
03-18-2013, 08:45 PM
![fordracing65's Avatar](http://www.clubcobra.com/forums/image.php?u=42910&dateline=1329894507) |
AZ
Originally Posted by Danr55
I just changed my FE from a flat tappet to hyd. roller and I chose a Howards Cam with the Morel lifters. I've been running Comp Cams but the available profiles for FE motors seemed limited unless you went with a custom grind. I found exactly the grind I wanted with Howards. As for roller rockers and springs, I got the entire assembly from Precision Pumps in California. So far, they've worked well.
Hi Dan, does your engine now feel stonger or weaker or the same after the switch???
PRIDEnJOY
