Old 03-20-2013, 11:11 PM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
The fender badges that I have, have fairly long studs welded to the back ( they came like that) requiring holes to be drilled to mount them. Some inner tube rubber cut to fit behind the badge and on the inside between the vents and the body with holes drilled in the top flange of the vents so the badge holds the top and some double sided tape on the bottom......been there for 24 years with no problems ......I have removed them once for a re paint........very easy .....
