Marty,
What is the reason for a panhard kit? With the CR four link, a panhard bar is not required or needed.
Are you changing to a triangular suspension or plan on unhooking the upper trailing arms?
If you are having trouble with side to side suspension movement you probably just need to change the trailing arm bushings.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
