Dont forget to make sure there is no twist in the screen or you'll end up with a crack
A good way to check is to fit the side brackets without the glass and frame, then stretch a piece of string diagonally from the bottom corner to the opposite top corner bracket, then the same with the other one. Where the 2 strings touch should be exactly in the middle.
