Looks great!
I've also picked up a couple of used SW 240 pumps (mine are not as pretty as yours just yet) from eBay and I've been intending to install them for about 2 months. The trouble is, the ones I have on my CSX 4000 work so well, I fear that I'm making a mistake with the swap! I guess if I install them and they don't work as well as the Bendix style, I can always swap again.
My current set-up has the electric pumps running in parallel that feed into a "T" on the pressure ("out") side of the mechanical pump. The mechanical pump draws fuel from the higher pick-up point on the fuel cell and the electric pumps draw from the lower pick-up. I rarely use my electric pumps but when I do, they are both switched from one, single pole switch on the dash.
Mike
