Question? on Engine and Trans Installation in CSX Roller
Getting ready to install the engine and transmission into my CSX roller. The roller is an HST car without the removable crossmember. My question is can the 427 SO engine be installed in the car as 1 unit engine + trans? The trans is a Top Loader with a larger stock FE bellhousing.
If not in 1 unit I've heard the trans will need to be installed inside the car removing the seats and trans tunnel? Can the trans be put in place then bolted to the bellhosuing from the bottom of the car?
Any guidance tips and tricks in advnace is appreciated.
Thanks,
