i ended up ditching the efi and going to carb, stuck the o2 sensor in a primary pipe for monitor purposes. i asked an efi guru if there should be any compensation on sampling rates for the efi using the primary pipe only and he said no. only thing is you are sampling only one cylinder, so it better be a good one.
