Use the OEM fiber washers. Occasionally they seep because the sealing face of the Banjo has a flaw in the sealing surface, if so carefully dress it with a file without removing too much material. After installing fresh washers snug them down a couple of times after heat cycling. Don't overtighten or the bolts will be damaged.
Rick
