Originally Posted by COACH MIKE
I have a stroked 427 (482) side oiler with pond block. I am told the oil pressure will bleed off as the engine gets to running temp (180 h2o temp and 200 oil tmp). I have 100 miles on the engine and when the temp gets to running temp the oil pressure at 1200 rpm is 18 lbs and 35 lbs at 2000 rpm. The oil pressure does increase quickly when rpm's increase.
There have been many, many
"what should my FE's oil pressure be" threads. Do you normally idle at 1200 RPM? What is the viscosity of the oil that you are running?
